N2C...CruZer
Date:  1-10-2017
Number of Hours:  1.50
Brief Description:  Rivet passenger side/Start Pilot side
Riveted the L angles to the passenger side skin.
Drilled the bottom longeron of the pilot side skin. Note, the most forward window is missing from the pilot side skin. I had it delivered this way. I hope to be able to add a cargo door in this location. I did trace the outline of the window on the inside of the skin (using the passenger skin in reverse) just in case when I get to it, it won't work...then I can go back to original form.
