N2C...CruZer
Date:  5-13-2018
Brief Description:  Milestone...Hung the Engine
Used the engine hoist...this was actually quite easy. Put the bottom bolts in first...the nuts go toward the front, won't fit the other way. Torqued the bolts until they bottomed on the steel spcers, then just enough to get the holes for the cotter pins lined up. The airplane sits on the floor now with no added support.
Note the offset of the engine
