N2C...CruZer
Date:  1-18-2016
Number of Hours:  3.00
Brief Description:  Bottom Skins
First I finished up all the L's that get attached to the bottom and top skins, all are now done for both wings. I used the bottom ones that I drilled for this wing as a template and also drilled the second hole in from each end so they can be easily mounted and then final drilled.
I wasn't crazy about the support structure for the skins around the spar extension, the plans call for the skins to get riveted to each other without a support structure underneath. I'm sure from an engineering standpoint this passes muster. But from my paranoia standpoint it doesn't, so I added two aluminum angles top and bottom of the spar extension that will get drilled for the skins to attach to.
Laid the bottom skins out on the skeleton, temporarily bolted in the strut bracket and clecoed thye two strut bracket supports in place.
3 stacks of wing L's
Aluminum angles added to spar extension
