Continued with the elevator cables. The long ones are about 9.5' and end near the aft end of the bottom hatch. The shorter ones get fabricated after attaching the fitttings with wire to the longer ones, screwing that to a piece of wood, marking the screw holes, then making the cable the same length. I used my tensionometer (bought years ago on ebay) and adjusted the cables to 25 lbs. The hardware is not permanent until final rigging.
