OK...the JB Weld mod on the bearing blocks came out good. It al fits together well. The iffy thing in this whole installation is drilling the holes fro the aft AN3 bolt...it is a very inexact science. The photo guide and homebuilt help videos instuct you to fab up a a piece of aluminum that duplicates the correct angle and location of the hole...however the inside of the area where the bearing block docks is not on the same plane as the firewall because there is the additional thickness of the center firewall channel to deal with and there are rivets inside that area, so you need to account fror that additional thickness, otherwise you're going to put the hole in the wrong place. So in doing it I had to elongate the hole a bit on the right side and I ended up getting the left one correct. I'm going to fabricate an extra couple of brackets for the front to beef the whole thing up.
