N2C...CruZer
Date:  1-11-2018
Number of Hours:  1.00
Brief Description:  Nose Wheel...Drill Fork
Note: I am using a CH750 STOL nose wheel, w 6' rim (also CH750 STOL Main Gear Wheels)
Used a piece of control cable to wrap around the nose fork to get the length...divide by two and you have the middle...use the same control cable to mark it. Clamped the fork in place and drilled. As each hole was done I inserted a AN4 bolt and tightened.
