Brief Description: Riveted Firewall, brake cylinders, fire barrier
Installed the brake cylinders, didn't finalize the nuts and bolts...I'm sure there will be adjustments.
Used 3M Fire Barrier around the perimeter of the firewall, clecoed and riveted...quite a mess.
Riveted the cabin sidewalls too and bolted in the lower engine mounts. Don't see how the bolt is going to go through the firewall to the lower engine and not have that front bolt of the lower mount interfering...don't know why Zenith makes these lower ones so small. Anyway I put the bolt in the front hole but left the nut off...I'm sure I'll be changing this.
