Another 2.5 hours deburring but now everything is pretty much done, all holes, corners and edges. on all parts for both wings. the only deburring left will be the skins and whatever holes I have to drill into the spar caps. The secong wing should go much quicker. the other thing I'm doing is that aywhere i need to create a part (lots of L Brackets) I'm also creating the ones needed for the other wing.
So I got the root rib clecoed in and the rear spar, caps and doublers as well.
