Brief Description: begin lower cowling nose repair 2
Looks like the cowl inlet reduction mod I did in 2012 was the culprit. Eiither the BID was not wetted through properly or the carbon fiber cowl was not prepared adequately. The damage from the drop was to delam the inlet BID from the cowl itself. Ground away delamed BID and filed gap between BID and cowl. Plan is to flox the gap, then add 2 BID on top
ground away damage with dremel & permagrit sm cone
