Brief Description: sand & prep all control surfaces; prime
Final sand and prep of rudder, HS, elevators, ailerons and wing tips. Clean with acetone. Rig up cable outside between 2 trees. Perfect day to spray. 60-70, low humidity, no wind and no rain in forecast
Gray Enduro Prime from Kirker, per Nate Mullins. Good stuff, dries quickly. 1.8 MM tip in HF HVLP gun. Will need a little bit of add'l bodywork... pin holes and some bad body areas. Then will add add'l coat.
Forgot to take pic of parts hanging on cable, which worked real well. Shot some pics after I hung them up in garage
