Brief Description: add 2 BID skirt around canopy frame
Had previously measured and cut BID to specific lenghts and the varying widths needed. Those measurements were marked on tape for easy reference. Added peel ply. Seems to have worked out pretty well. Will see when peel ply and tape is removed.
Not totally pleased width the gap left between bottom of canopy on each side of the fuselage. May need to add some micro and another BID or two to bring it out flush.
Going to take it all apart and clean it up; reconnect hinges and see what it looks like. May be able to do rest of work on the bench which will be easier
