Brief Description: fab and install hinges to canopy frame
Fab hinge brackets; trim canopy arm to fit, drill holes for hinge; match drill hinge to canopy frame
Fab backing plate; match drilled it; floxed to frame.. probably should have used nuts plates as this plate will not be accessible after canopy and skins are installed
Will probably flox screws in; or use red loctite. Did not have my complete screw kits with me as my truck left me sit at KCXY
