Brief Description: measurements for canopy hinges - to fit AFS 5500
Manual calls for setting hinges 9.5" either side of center line. IN speaking with Nick at SNF, he said 9 to 10" is fine. I am trying to have enough room to use AFS 5500 EFIS which is slightly deeper than the Dynon, but at 3.75" deeep, the AFS should be fine. Have 4.75" from hinge swing to face of panel. Moved hinge line to 9" either side of centerline... this should line up very close to the "gap" in the back of the 5500 between the box/cooling fans and where the sub D connectors line up.
Really want to stay with AFS equipment as I have that in the Lancair abd would much rather have the same look and feel and logic if at all possible. I have been very happy with the AFS 4500-3500's in the Lancair. Work well and the manual is very good.
