N144GP Lancair Super ES
Lightning (EAB-LSA)
Elevators
4-21-2013
modify hinge for trim tab
Not happy with the tightness of the hinge pin and the difficulty of getting it in out out. Caused by the mis-alignment after the close-out.
Decided to modify the hinge tab by taking out two sections of the hinge holes. Will leave me with a three section hinge... no single point of failure.
If this doesn't work satisfactorily, I will consider getting a replacement elevator/trim tab and starting over.
In hind sight, I wish I would have screwed in the tab hinges, rather than floxing them in as the manual indicates.
Will work on the hinge pin next session.
hinge tabs removed
on both elevator and trim tab
Lightning (EAB-LSA) Home
4066
Cowling
Elevators
Firewall forward
1070
Gear and wheels
Horizontal Stab
Move
Research, prep shop,
Vert Stab - Rudder
393
Wiring
Lancair Super ES Home
