N144GP Lancair Super ES
Date:  3-31-2014
Number of Hours:  1.50
Brief Description:  batt box; hole for loom; mount ECU inside FW
will fab cover & grommet for loom FW access
Ending up moving coil brackets as they were within the 100mm minimum spec from ECU.... I knew that but got on a role installing stuff and was wrong. See 4/6/14 log
fabbed brackets and hold down strap
drilled and filed hole for loom cable access
ECU position om left side of aft side of firewall
