Brief Description: clean up SS firewall; fit and cleco to fusleage -
Goof off, razor blade and acetone to get all tape and residue off of SS sheet. Took a good while and a lot of patience. Firewall sheet is now pre-cut by factory...probably a good thing since it is some tough shit.
Need to figure out how different FW layout will be with using the UL engine instead of the Jabiru.
May just move to wiring layout and bodywork/primer in the meantime as the wx is pretty nice.
