Brief Description: add hinge closure to nose fairing
set hinge pin line just inside TE of fairing. Looks OK. Later found out (manual section for main gear) that the hinge should be inside by a full 7/8"... the TE just pressure closes on itself. Not clear at all in nose gear section.
Will leave as is ,,, it is fine.
Used 3/32 CS pop rivits as called out in manual. Came out shitty. Hinge material was not firm against fairing. Drilled 2/3 of them out and redid with soft, CS SQUEEZED rivits. MUCH better! Will do other 2 fairings with squeezed rivits.
