N144GP Lancair Super ES
Date:  7-14-2014
Number of Hours:  3.25
Brief Description:  prep for inside paint; clean and prep paint guns
Clean 2 paint gun kits form HF with mineral sprits and then water. Zolatone instructions call for a spray tip of 2.0-2.4 mm (.080-.090). Largest HF tip was 1.8mm. Decided to try to drill it out to .082, #42 drill, which should be about 2.2mm. Worked great! Used the 1.8 tip rod without modification.
This would be my first attempt with a HVLP spray gun. In hindsight, I probably could have gotten away with no masking of the space. There was very little overspray with the HVLP gun.
Vacumn and wipe down with acetone.
plastic around and small parts hung
masked off wall
masked off wall
