N144GP Lancair Super ES
Date:  12-23-2012
Number of Hours:  1.25
Brief Description:  fit HS spars
Lots of fit and trial and error to get all to fit. Still not entirely done. Some of the things done to make it work..
-clean epoxy blobs off of inside rib at spar
open up slots in fuselage for spar pass through; width and height
-sand forward inside of L HS to allow full seating, will need to add some flox to a lousy hard point job from factory. Took off about 1/16" at front so that HS would have clearance at fwd edge
enlarge/enlongate holes in L spar slightly; was short about 1/32" clearance no matter how I fiddled and all the other steps above
ground 2 hardware store 3/8" bolts at end to create a pin that could be used to center and set spar holes.
Still don't have hardware from Arion so didn't have the final AN6-16A bolts to snug up
Still need to open up L HS holes slightly to allow bolts with threads to fit.
Will use laser level to set both HS's before drilling AOI holes
both HS halves on with pins
right side
right side
left
left
