Brief Description: measure and finish fab of long aileron tubes
Manual sucks. And, no way the pre-drilled holes in control stick were going to work for aileron tubes.
Drilled add' hole .75" up from old top hole.
After a lot of trial and error.... mixer tubes up top, front of stick flange, bolt front to back.
Long aileron push/pull tubes, lower hole, behain stick flange, bolt back to front. Tubes were 104.5"... verifies by putting left wing on with Angie's help. Made right tube same length without verifiying with wing on as is was 90+ degrees in the sun today. Should be Ok.. will re-do later if needed
