Had to maneuver the cradles around and lift fuse up to get enough clearance to insert gear legs into tube part of main spar. Snug fit.
Next session will calculate and mark toe in and bolts gear legs to spar tube.
Seems like a lot of camber, but other Lightnings seem to be about the same. The Lancair ES I built also had a lot of intial camber, but it settles out when the weight was all on it.
It is what it is, because it is not adjustable in any way,
