Brief Description: drill rest of firewall holes - from insode & outsi
Mostly AN3 around outside of firewall to fuselage flange. Engine mount holes are AN4. Drilled to #30 first and cleco'd all around, then went back and drilled out to 3/16".
Drilled AN4 engine mount second holes from inside using right anlge air drill... what a pain.
Going to spray Zolatone interior before permanently installed SS FW to fuselage flange with RTV and AN3 bolts... will be much easier to spray inside with engine and firewall off. Plan to lift firewall and engine off together. WX is warmign up...will soon be able to spray some paint.
Still waiting on prop form Sensenich before moving ahead on cowl fitting and finishing. Last word were blades were done but waiting on the hub from a vendor. Goring on 12 weeks on a quoted 4-6 week delivery
