Brief Description: batt box; hole for loom; mount ECU inside FW
will fab cover & grommet for loom FW access
Ending up moving coil brackets as they were within the 100mm minimum spec from ECU.... I knew that but got on a role installing stuff and was wrong. See 4/6/14 log
