Brief Description: fit up rudder pedals; tighten all bolts. No pics-
Fitted up rudder pedals. Mixer tube is about 1" too long. I guess because the pedals are too close together. They were set per manual measurement (12" off center if I recall correctly). They look to be well centered to seat center. Will haved tube shortened and nut welded on, of may just check McMaster-Carr for a suitable alternative.
Need to come up with a method to secure pedals on tube. Thinking about using adel clamps, maybe even with a pop rivit through it. Manual call for using 1" scrap tubing. Only 2 problems with that...1) 1" isn't the right size to fit over 1" tubing, and 2) there is no tubing in kit of a size that would fit over 1" OD tubing. Probably some laying around Arion shop though.
