Brief Description: check sweep of wings; AOI cont'd
sweep; left side from top of VS to TE of wing at 135"from root = 205 3/4" right side is 206" supposed to be within 1/8" and adjusted by adding washers at AOI bolts. Need slight adjustment to TE of left wing...but everything is tight. To get that extra 1/8" would likely require moving spar box. Not going to do that... leave as is.
