N144GP Lancair Super ES
Lightning (EAB-LSA)
continue work on fitting HS
grind front left hard point...binding there
open up both fuselage slots
use hammer to tap in pins...OK
inside of rib is binding between blue marks - grind
both pin-bolts in
left side after all seated in
Lightning (EAB-LSA) Home
4066
Cowling
Elevators
Firewall forward
1070
Gear and wheels
Horizontal Stab
Move
Research, prep shop,
Vert Stab - Rudder
393
Wiring
Lancair Super ES Home
