Install z-brackets on the baffle. Drill z-brackets to the baffle. Install pop-rivets on the center z-brackets and place the tank on the wing spar. Looks like the inboard clecos have to be removed... they interfere with the tank setting all the way down onto the spar.
Drilled the holes for the tank attach.
Refitted the bottom skins so prepare for wing/twist measurements.
