Brief Description: Complete leading edge, cleco in place
Finish up the last couple of rivets on the leading edge of the right wing. Cleco the leading edge in place on the spar and check fit of all of the pieces parts. No clue if I should attempt to put the shop head on the inside of the leading edge or on the spar -- normal convention would be to put the shop head on the spar web but that would mean that a failed rivet will be a PITA to remove! Drilling inside the leading edge would not be something fun... I will check with Van's tomorrow and get a reading on this one.
