Brief Description: Attach leading edge to right wing, put skin on rig
Disassembled the leading edge (doh) and trimmed rib #5 to fit around the rivet on the main spar. Not a big deal... I knew I had it coming.
Fit the leading edge to the right wing. Put in the joining strip used to connect the tank to the leading edge.
Match drilled the leading edge.
Started assembly of the right tank. The skin is on and the tank is in the cradle waiting for me to start work on the bulkhead. I guess its time to order some pro-seal.
