Mikes RANS S-19 Project
Date:  4-28-2013
Number of Hours:  1.50
Manual Reference:  Text Manual 02B-2
Brief Description:  Removed Protective Film from Skins
Removed the blue protective film from the outside surfaces of the rear stabilator skins. I used a pencil-type soldering iron to separate the film into strips so that it would peel off easier. I found that strips about 3" wide worked best. This is a time-consuming process!
