Mark's Web Site
Date:  11-2-2018
Number of Hours:  3.00
Manual Reference:  PAP - G8
Brief Description:  Fuel Calibration (PAP - G8)
I spent a little time calibrating the fuel system. I'm starting out with using no ethanol, 91 octane from one of the equipment rental place in town. I started out with only 10 gal (two 5 gal containers), but after starting through the sequence I realized I was supposed to completely fill the tank. So I left the plane on the charger and the Dynon in the middle of the fill sequence. It didn’t time out by the time I got back with the next 10 gallons. I measured out 2 gal in my spare 5 gal container, and then I just kept using that container to transfer 2 gal at a time. The procedure asks you to click the add button after each 2 gal are added. This works until you get to 16 gal…the tank gage shows full and when you add 2 more to take it to 18 it doesn’t change the mV and you get a notification from Dynon to accept or discard. Well after reading several comments from Vansairforce.net, I chose to accept. My understanding is that the float is all the way to the top even though the tank isn’t full. So I continued to take it to 20 gal and pressed full. That’s done.
Also today I got my carpets in from Flight line. I asked Abby for SLSA version that you see in the factory planes. I like that carpet better than the full spread. It looks a little more rugged and less weight. I provided a template for the baggage floor, which worked out great. I really like the look of the interior now, along with the arm rest that match the seats. Abby did an excellent job.
Carpets in place
Carpets in place
Carpets in place
Carpets in place
Almost ready to fly
Almost ready to fly
