Mark's Web Site
Date:  7-4-2018
Number of Hours:  1.00
Manual Reference:  33-02
Brief Description:  Misc items and covers (33-02)
I installed all the covers in the baggage area and secured the fuel tank including attaching all the fuel lines. The back cover was a little difficult to get all the holes to line up and there’s nothing rigid behind it to resist some pressure on the screws. It will be easier to remove than it was to attach. I ended up using some clecos to hold a few of them until I could get all the screws in place. I also attached the flap arm assembly and opted for the 0.5” shorter spring to make it a little easier to press the button. I installed the crouch seat belts just so I could install the cover under the seat cushions. It starting to look a little more finished.
Back baggagecover and fuel tank in place
flap arm installed
flap arm installed
crouch strap in place
