Mark's Web Site
Date:  6-24-2018
Number of Hours:  0.50
Manual Reference:  44A-02
Brief Description:  Auto pilot servo install (44A-02)
Since I had all the floors out and the fuel tank pulled out, I decided to move onto to the auto pilot servos. The first step is to make a couple of pull rods. I cut then close to length with the dremel cut-off saw, and then filed it down to size. Drilling the ends of each rod was a little challenging. I clamped it in the drill press, but I didn’t want to clamp down too hard a crush it or scratch it. So I ended up taping the outside of the rod, then tightening the clamp just enough to keep it from rotating. I used the vice clamp for the threading operation. I have some plastic covers on the jaws that keep it from messing up the outside of the tube.
pull rods threaded
pull rods threaded
pitch and roll pull rods complete
molex connections installed on servo
