Mark's Web Site
Date:  5-21-2018
Number of Hours:  0.50
Manual Reference:  42M-03
Brief Description:  Control Module Install (42M-03)
I’m not quite sure I understand the build order here, but from the pictures in the previous sections and in this section it looks like this is section gets assembled first. Everything plugs into the control module so it gets attached first. Then all the fuses go into the switch module and the extra fuses get attached to the map box door.
Installed control module
Switch module with fuses
Extra fusses in map box
