Brief Description: HS Front Spar Service Bulletin (SB 18-02-02) Log
It would really help to have small hands here. I’ve had to assemble and dis-assemble the bolts several times to get everything lined up, drilled, deburred, re-assembled, re-lined up, then disassembled to get everything back together…if that makes sense. I think you will appreciate those words more once you try it for yourself. Those that have already completed this should know exactly what I’m talking about. I wasn’t completely satisfied with my old version of the spacers that the rudder stop hits. They just didn’t fit right…plus I mixed up which ones went in what spots. So I decided to order some more aluminum tube from Vans and make new ones.
