The hardest part to install the oil hoses is to figure out the routing. The pictures help a little, but it’s still a challenge to get the V-213 hose around the back, up underneath and attached to the oil cooler. I’ve got everything in and finger tight. Next step will be to attach the cowl and position the oil cooler to tighten everything up. Then I will be done with section 49…or at least as much as I can do for now.
