Mark's Web Site
RV-12
Attach Oil Cooler (49-12)
With the upper screws in place I drilled the lower holes through the guides, I then added the bolts. I tightened them down just enough that the guides wouldn’t rotate with the oil cooler removed.
lower holes drilled
cooler guides attached
oil cooler attached
RV-12 Home
1257
Certification
176
78
Finishing
144
290
Flight
348
PAP
Service Bulletin
241
