Mark's Web Site
Date:  11-13-2017
Number of Hours:  1.00
Manual Reference:  38-07
Brief Description:  Attach nut plates to fwd cowling (38-07)
I first final sized all the holes to #19. Second I used a tapped out nutplate and used the screw from the inside to hold the nut plate on the outside. I then used the nutplate as the guide to drill the #40 holes…adding clecos as I went. Once I was done drilling the #40 holes I tossed the tapped nutplate, I then countersunk the holes for the flush rivets. Everything looks like it fits up nicely.
final drilled holes and attached nut plates
countersink nut plate rivets
side hinge pin nut plates installed
