Mark's Web Site
Date:  8-21-2017
Number of Hours:  3.00
Manual Reference:  34-16
Brief Description:  Canopy sanding (34-16)
Before I get to the engine I wanted to make sure the canopy is fitting better. I added some resin/flox mixture in front of the pivot bolt and then sanded it down to fit. I was able to reduce the spacers from 3 washers down to 2. I'll continue to work on it to see if I can get it even closer. For now, it seems to be working fine. I went ahead and purchased another set of struts since mine was making an awful sound when raised, but it seems to be better now. I'll hold off to install at a later time.
added some more resin/flox and sanded to fit
reinstalled canopy and sanded for clearance
canopy wroking well with only 2 washers
