Mark's Web Site
Date:  7-19-2017
Number of Hours:  0.50
Manual Reference:  11-08
Brief Description:  Trip tabs installed (11-08)
In prep for Oshkosh this year I wanted to get the trim tabs installed to make sure all the controls worked freely and compare to some flying RV-12's. I sized the hinge wire and with a little/lot of effort slide it in. Make sure when you put the second trim tab on that the 90 deg angle is facing the right way (down). I caught myself just before sliding it in. I also noticed that after 2+ years of ignoring this part of the build, that I was missing some of the hardware (cotter pins and ANS-10A bolt). Undoubtedly, I used on other parts of the plane somewhere.
For a while I've been wondering why the controls weren't balanced. The control stick would just fall all the way back, so I was thinking that I had too much lead weight on the elevator assembly, but after installing the trim tabs it looks like it perfectly balanced. Nice job Vans.
Attached trim motor to tabs
ready for take off or flare
trim tabs moves freely
