Mark's Web Site
Date:  6-3-2017
Number of Hours:  1.00
Manual Reference:  34-15
Brief Description:  Remove canopy (34-15)
In the process of removing the canopy, the frame dug into the top skin and bent it a little. I think I should be able to bend it back...this is more for appearance. I recommend loosening the fiberglass everywhere and tilting the canopy up, then removing the strut bolts, before removing the pivot bolts. I'll know better next time ;)
Fuselage cleaned up a bit after removal of canopy
the top skin caused some damage to the frame...no biggie
the frame caused some damage to the top skin...should be able to fix it
