Mark's Web Site
Date:  4-25-2017
Number of Hours:  0.50
Manual Reference:  34-13
Brief Description:  Cut foam blocks to canopy (34-13)
I marked the angle on the foam blocks and then just used the hack saw to cut down the line. The foam cuts really easy, then I sanded it smooth to match the canopy arm contour. I only had a 3/4" step drill so I went with that for the bolt hole and it seemed to work just fine for now. I also worked the foam back into the skirt curved portion which cut a groove and made a nice tight fir for the foam.
trimmed block and tested the fit (left side)
right side fit check
not bad for just a hacksaw blade
