Mark's Web Site
Date:  3-8-2017
Manual Reference:  34-09
Brief Description:  Fabricate canopy lift handles (34-09)
It looks like I'm done traveling for a little while, so now I can get some more work done on the plane. Today I started fabricating the canopy lift handles. I used my dremmel to cut pretty close to my lines, and then I finished sizing it with the file. To get the correct/consistent radius for the corners I used the extra bushings that were left over from the plastic canopy struts. This worked out well to draw the radius lines, and then I just filed them down to the lines. Once the edges where all smooth I drilled the first hole and lined it up to drill the second. They seemed to have turned out nice...now back to the canopy and frame.
Holes drilled
Holes drilled
edges rounded
edges rounded
complete
complete
