Mark's Web Site
Date:  1-4-2017
Manual Reference:  32-10
Brief Description:  Flaperon torque arms (32-10)
I ran into a little snag putting things back together. One of the bolts for the control arm never got tight and just stripped out...so much so that I couldn't even get it off. I spent a couple horse with a hack saw blade trying to slowly whittle away at the bolt. I was able to get it apart. Now it's all hooked up again and the torque arm is working.
Had to use a hack saw balde to remove the stripped bolt/nut
stripped bolt removed...finally
torque arm installed and working
