Mark's Web Site
Date:  1-1-2017
Number of Hours:  3.00
Manual Reference:  30-03
Brief Description:  Wings trial fit (30-03)
Well took the plane out of the garage to do a trial fit of the wings in prep for setting the torque tubes. This is the first time I went to fit the wings and I should have known better, but that is rarely the case, but I ended up causing some damage to the side skin. This is the area next to the wing slot. The wing got a little twisted as we were removing it and crunched in the skin. I bent it back the best I could, but there is a tear. I'll check with Vans to see how I should repair, but I think I can just blend out the tear. I did have to blend the inside edge a little (see 1st picture), because it was binding up with the top of the wing spar. I also should have removed the connector plugs, prior to trying to fit the wing. I ended up snapping off one of the pins trying to wiggle the wing into place. Now I get to figure out how to remove the wires so I can replace the connector. The next wing was a little easier, mostly because of all the lessons learned from the first wing. I made sure to remove the connector plug ahead of time. I needed to grind a little off each of the hons on the fwd and aft side of the wing. It was really hard to get the pins in place as well, but that's probably a good thing. I installed the flaperons prior to attaching the wings.
needed some material removed to clear the wing
damage to side skin when wing twisted
tried to force fit and ended up with broken pin
