Mark's Web Site
Date:  12-15-2016
Number of Hours:  3.00
Manual Reference:  31B-25
Brief Description:  Group wires and add shield (31B-25)
Remember about how I split the wires on either side of the rudder pedal mounting blocks...well now it's fixed, except my back is not. I had to completely remove all the mounting blocks and slide the assembly out to re-route the wires. Hint: route them all on the left side from the beginning. I had to crawl under the panel to get in there with the seat wedge jammed into my side. With the help of my son Benjamin, I was able to line up the bolts and re-install the mounting blocks...only to realize I had to slide the shield over the wires. So again I loosened all the bolts and slide to drop the pedals down enough to slide in the shield. That worked, but then I had to slide a screw up under the panel, between the two pedal assemblies all blind. So I figured if I lay on my back, with the seat wedge driving into my back I was able to view the crew (upside down) and get it lined up with the hole. I'm sure there is a better way to do this, but I couldn't figure it out. Anyway it's done.
Next, I went through the rest of the wires and zip tied and cleaned everything up as much as possible.
added wire shield and zip tie bracket
zip tie wire bundles
wire cover plate
wire cover plate
