Mark's Web Site
Date:  12-7-2016
Manual Reference:  31B-17
Brief Description:  Headset connections (31B-17)
I taped the ends of the wires as I routed them through all the passages ways, but somewhere along the line I broke one of the connectors, so I had to replace it. I opted not to drill a hole and install the aux jack for a go pro and just stuck with the headset jacks. Make sure to organize your wires here since it starting to get a little crowded and easy to get the wires all tangled. I used a multi-meter to check that the jacks were isolated from the frame...checks good.
broke a connector trying to route it
fixed it
fixed it
head set connectors installed and tested
