Mark's Web Site
Date:  10-10-2016
Number of Hours:  1.00
Manual Reference:  31B-05
Brief Description:  Run WH-00046 wire harness (31B-05)
Started routing the WH-00046 wire bundle through the fuselage. I taped each wire end to the bundle to make it easier to pull through. The instruction don't specify which location to run the wires, so I chose the bottom holes.
runing wires through the tunnel
ran all the wires through each section of the tunnel
over the rudder peddals
