Mark's Web Site
Date:  10-7-2016
Number of Hours:  3.00
Manual Reference:  25-04
Brief Description:  Attach baggage corner skins (25-04)
Deburred and prepped the baggage corner skins, then clecoed and riveted in place. There are a lot of spots to rivet here and several layers that need to be lined up and sandwiched in the right sequence. It’s best to just think about airflow and rain flow around each of the seams. I tried to think about it as I primed the surface that I thought would be sandwiched, but as you can see from the pictures I got a little carried away. No worries, it will all come off when the exterior gets painted.
Left baggage corner skin attached
Right baggage corner skin attached
tail section attached
