Mark's Web Site
Date: 9-1-2016
Number of Hours: 5.00
Manual Reference: 29A-06
Brief Description: Attach Fwd Upper Fusalge skin (29A-06)
I final sized all the holes, deburred the edges and dimpled per the instructions. I added a little curvature to the fwd edge, but I don’t think it needs much…the instructions don’t specify how much except that it should fit nicely, which it did. I primed the inside surface and once it was dry I applied a very generous layer of boelube (as per the instructions). Next I applied a very small bead of Permatex silicone sealant, just as instructed. Then, with the help of my wife, Cyndi and Stephen (now 18 yrs old and about to leave for a mission in Toronto, CA), we laid down the fwd skin and I clecoed it in place. Then came back and screwed it all together. Everything fit nicely, so I continued on to attach the panel strips. Many rivets and plate nuts later it is all together. Of course I couldn’t pass up on the opportunity to see what it looked like with the instrument panels in place. I like it, now I just need $$,$$$ for some instruments (the second most expensive kit).
Prepped all surfaces, applied sealant and screwed it together
Added the panel attach strips
Of course had to see how it all looked with the panels in place
Copyright © 2001-2020 Matronics. All Rights Reserved. |
